Gold Sublimation Film - Polijet Plus 180microns - 148 x 210mm
Ucase Ltd
Re: Gold Sublimation Film - Polijet Plus 180microns - 148 x 210mm
Post by Ucase Ltd »
Er - Yeah Good idea. Pm'ing you now.
Hi Ucase
If you do not mind me asking...
Do you not use film for your 3D cases then?
Also, do you mind em asking, what machine do you use?
Ucase Ltd
Post by Ucase Ltd »
Hi Social,
I used to use the 3D film but I was given some bad advice when setting up and after wasting loads of cases I realised it just wasn't suitable for use with my ST3042 machine (unless I bought the extra internal thingmebob which isn't available anymore).
So now I just use paper.
Fair do.
What wrapping method do you use?
I have found with paper in that machine that the best wrap is the one where you do not actually wrap the paper, but instead tape it around the puck (someone suggested it on here, I tried it and it worked)!
I am using settings of 1 minute 50, very hot puck on Subliblanks cases (among others), oven is set at 410, but is normally around the 360 mark
What about you?
Ucase Ltd
Post by Ucase Ltd »
In terms of wrapping I think we're doing the same thing - vertical tape around the puck just in the top and bottom centre. No taping around the sides.
But my times are very different.
I pre-heat puck to 190c then cook for 6 minutes.
But I am using different cases - bought in bulk from szmicrotec.
Having said that my business seems to have gone in a different direction and I don't actually do many phone cases anymore. Which means I have hundreds of blank cases I'll probably also be flogging soon to get them out the way.
caseseller
Post by caseseller »
Ucase Ltd;102331 wrote:In terms of wrapping I think we're doing the same thing - vertical tape around the puck just in the top and bottom centre. No taping around the sides.
Not sure if you care, but I solved the bubbling problem with gold film, works like a charm, wont ever deal with paper and corners again.
