sublimation on 100% cotton
Re: sublimation on 100% cotton
spongerobinson
Post by spongerobinson »
Looks good Paul! Going to try this stuff at some point, but don't use a Ricoh so will have to wait til more ICC profiles start appearing. Have you tested washability yet on that t-shirt?
Oh, and on a different note, that heat press looks like a nice bit of kit. Are they good?
Quinsfan
Post by Quinsfan »
I found that if the image was a large block of colour the finished feel was just rubbery. The way it has been promoted makes it sound that the final image was going to be in the cotton, like sublimation would be, not on top like a vinyl transfer. I have been disappointed with my results for large images. I have used it for doing smaller multi coloured logos or text though and it has been fine.
spongerobinson;100747 wrote:Looks good Paul! Going to try this stuff at some point, but don't use a Ricoh so will have to wait til more ICC profiles start appearing. Have you tested washability yet on that t-shirt?
I did it only last night but planing to put it through few washes and will report back.
Press is lovely and i actually prefer it over my swing away that is in the dark corner somewhere now :)
Quinsfan;100748 wrote:I found that if the image was a large block of colour the finished feel was just rubbery. The way it has been promoted makes it sound that the final image was going to be in the cotton, like sublimation would be, not on top like a vinyl transfer. I have been disappointed with my results for large images. I have used it for doing smaller multi coloured logos or text though and it has been fine.
you are right. it has bit stiff feel, but not to much. what you need to do after removing paper is - stuck it under the press again for 3 sec and then stretch immediately after :wink:
this will make it MUUUUCH softer.
Isaac11
Post by Isaac11 »
I just received the paper and did try to sublimate.
But even if I print at high speed on plain paper, ink are very wet and make some line when printing
vB_ID:3414
vB_ID:3414
Fichier 26-04-2015 12 52 27.jpg (35.54 KiB) Viewed 2765 times
Do you have some other recommendation ?
is this with RICOH?
Isaac11
Post by Isaac11 »
Yes of course !
It's the SG7100DN
But I'm printing on Mac do you think this can change something ?
And I use the ICC Profil Subli2Cotton
I print from mac too and use same icc. Dont have this problem on my
A11kns
Post by A11kns »
How did this stand up to washes Paul? Any report back?
washing away to some point. but is VERY usable ;)
