ricoh sg2100n printer cant get sublijet catridges
Re: ricoh sg2100n printer cant get sublijet catridges
Hi guys more help needed! i have a ricoh sg2100n and cant get the sublijet catridges online! does anyone know if the ricoh catriges for other printers are acceptable i also have refill catriges so able to take refill ink but cant locate those either
thanks
thanks
The subli carts aren't supported in that printer. If you just need A4 the printer costs very little when bought with the inks.
Justin thank you so my printer is a waste of money then ? i feel like i have been wripped off big time
katy
katy
Hi i did find a supplier after posting this who said they do refills for my printer i have the catridges could this work concerned i cant find icc profiles either, was sold this printer as a package with mug press etc
Did you buy this from a 'reputable' supplier? The Ricoh printers use ink with a slightly different consistency, that means the third party inks you'll no doubt get offered for refilling are unlikely to work properly in the printer. In all honesty if I were you, I'd return the printer unused and look at a 3110 with proper inks.
The 2100 will take the 3110 carts, the same ricoh carts, the same refill carts, the same sublimation carts from Sawgrass and other sublimation ink manufacturers.
you'll then need an ICC profile, best bet would be a custom one from Paul, but the Sawgrass 3110 one may work OK.
thanks note sure who paul is as still try to work out this site lol thank u very much for info
ricoh advised they would not support any sublimation ink so was getting down hearted
pisquee;100539 wrote:The 2100 will take the 3110 carts, the same ricoh carts, the same refill carts, the same sublimation carts from Sawgrass and other sublimation ink manufacturers.
Scotty@BMS
I can only echo Justin's advice. There is a reason the SG2100 isn't supported by Sawgrass, though it was trialed I believe. It was found to be prone to banding, if memory serves. I'd return if possible and invest in the SG400. Bi-directional printing and a two year warranty.
