Adkins Press - Replacement Fuse
Re: Adkins Press - Replacement Fuse
Anyone know where I can get my hands on these. Found a few on the net but you need to order 10 in most instances, I guess Adkins would supply them but I wondered if anyone knew of anywhere else.
Fuse is a 12.5a 500v Quick Blow - Part Number 70-125-40
Not a huge problem if I have to buy 10 but only really need a couple....I hope!
logodigitizing
Post by logodigitizing »
hi
The fuse went on my press last year.. got it through Adkins and only had to order the one.. you could always try xpres too...
hope that helps
Cheers, just dropped Adkins an email, found them on eBay for about £3ea plus shipping so at least I know I can get them from a couple of sources, doesn't hurt to know! Maybe get myself a spare spring whilst i'm at it as they always seem to go!
Andrew
Post by Andrew »
When my fuses go on my adkins I always find them in Maplins.
Just looked on Maplin but couldn't find the right one.
Andrew
Post by Andrew »
They usually have a full range at the parts counter at the back of the store I go into. Not sure if it is the same as oline.
