In need of Iphone/Samsung Templates
A.Repton
Re: In need of Iphone/Samsung Templates
Post by A.Repton »
Hi there,
Im in need of templates for Iphone 5/5c & Samsung s5, iv searced the internet but to no avail.
If any one could send me a download link i would be very grateful
Many Thanks
tracyreed
Post by tracyreed »
Hi, I just draw round the metal insert, then scan the drawing for the template.
A.Repton;90742 wrote:Hi there,
Many Thanks
They aren't much more than a rectangle so just create a working space the size of the metal plus 3mm for a bleed around the image.
ArtyGamer
Post by ArtyGamer »
This is literally a two-minute job, and it would take you longer to search or wait for someone to post up a download link so you'd be better creating your own.
  1. Measure from left to right, then top to bottom
  2. Created a page in Photoshop at those exact dimensions (at 300 dpi)
  3. Add guides on all sides you'll always know the exact area for the print
  4. Measure the various apertures (camera, mic) then the distance they sit from the edges
  5. Placed a box that size on the page and move it to the exact position you'd measured
  6. Once you've done all the apertures, alter the canvas size to make it 3mm larger on each side for bleed
I just did the same thing myself as a test and it took me 2 minutes and 12 seconds. At least that way you know that you're getting it done properly rather than relying on someone else's work.
A.Repton
Post by A.Repton »
thanks guys :D
