Liyu TC631 Spooler Subsystem Problem
mikeoooze
Re: Liyu TC631 Spooler Subsystem Problem
Post by mikeoooze »
I use a Liyu TC631 cutter with Corel Draw. It has worked great for the past year or so, but I had to replace my computer and after I set up the cutter to work on the new PC I constantly get a "Spooler Subsystem Error" and I have to restart the "print spooler" each time. I am using it with Win XP as before, but I cannot fathom out what the problem is. The only way to get the cutter to work is by setting it up as a Graphtec cutter, it cuts ok, but I am unable to set offsets which is a pain. HELP!!
