Before I set about trawling through hours of You Tube video and reading umpteen web blogs, by any chance - does anyone know if you can select shapes other than the two given to you in Elements for the text to shape tool. I am pretty sure its easy enough to do in the full CS package but can it be done in Elements. Normally I would advise people to refer to the help section of an application - with the exception of Elements which is generally very basic
regards
arthur
