pens
Help in finding new products.
jennywren
Re: pens
Post by jennywren »
Does anyone know to get the pens that you can print on. Not printed on directly, it looks like you print on a sheet of paper and insert in the clear plastic. Or if you know a Company that prints on to the pens at least I can give the client two choices.
ASO Embroidery
Re: pens
Post by ASO Embroidery »
Hi Heather,
Not sure if this is of any use to you but I buy stuff off this company that display at the Printwear & promotion show if you Google keyringfab.co.uk. As it says on the tin its mostly Keying's they supply but they do one pen you can print and then it wraps around the pen with an acrylic cover you will see that you would normally need to buy the dye for cutting these but if you have a plotter cutter you could probably do it that way. As you will see the dye is not cheap but there stuff is very good and if you were planning on doing a lot of them it may be worth investing. That particular dye can be used on a number of different keying's as well so your not having to buy it just for one purpose. I use to sublimate all my keying's till I seen these and they are I think a better system and you certainly have a much wider choice doesn't cost anything to have a look. hope its of some help,
Sammy
jennywren
Re: pens
Post by jennywren »
ASO Embroidery;89383 wrote:Hi Heather,
Sammy
Thanks for that, I will have a look when I'm back in the shop, as the internet is slow due to the footballs.
jennywren
Re: pens
Post by jennywren »
I've had a look at the site but cant find the cutter, mind you my husbands shouting at the football without taking a breath, so it's hard to concerted
jennywren
Re: pens
Post by jennywren »
Now they've lost I'm gong to wearing earphones all night as he'll moan all night and in his sleep about them. Oh woe is me
ASO Embroidery
Re: pens
Hi Heather.
Maybe I've confused you if you look on the site you will see there is a section for assembly machines and cutting tools the way these work is you print them out as you would for dye sub but with a normal printer and don't mirror image and then you would use the appropriate cutter to punch out the design its then just placed on to the keying, pen etc.. and you attach the acrylic cover over it job done. I just noticed that they have a YouTube video up explaining how it works have a look there. What I was meaning on my first post was if you already own a plotter like a cameo etc. you could print them out and then cut them using the plotter. it would save you buying the punch which are expensive but as I said if you were doing loads of these you would get your money back Hope that makes sense
Sammy.
