craft robo cc330
- ASO Embroidery
Re: craft robo cc330
Hi
not got one myself I have a silhouette but I don't see why not its just that it may take a while to do the transfers.
Sammy
Sammy
don't see why not. you're only cutting out circles at the end of the day. as long as your settings are accurate and can cut 2mm circles you should be fine. if your offset or overcut is off though then your just gonna end up with a bunch of 6's or ovals!
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
It would also depend on what material you are using as a rhinestone stencil, and how new/good your blade is as the robo does not have the same pressure as the cameo
