Graphtec CE6000 - Possible Feed Issue
Re: Graphtec CE6000 - Possible Feed Issue
My new Graphtec doesn't appear to be feeding vinyl properly. Only really just noticed it when I hit 'sheet' to see what that did
It fed it through to measure it but goes off at an angle despite the vinyl being straight. I can only think one roller may be slipping. On my el cheapo cutter I can adjust the pressure on the rollers, is this possible on the Graphtecs?
Might be a 'stupid' suggestion but you have got both rollers over the knurled part of the driving shaft?
Oops, thanks Roger
Lol, I'm now going to use my admin power to remove every last trace of this thread!
