3oz Mugs
Littleshark
Re: 3oz Mugs
Post by Littleshark »
Hello friends,
I'm looking to sublimate 3oz mug, also called expresso cup in France.
Do you know if the element for 6oz is working with the 3oz ?
The diameter of these 3oz is 53mm and the height 66mm.
Thanks.
Re: 3oz Mugs
Littleshark;88377 wrote:Hello friends,
Thanks.
If you're mug press will clamp these smaller items tight then it will work. The height isn't significant, but the diameter is critical. You need to assure yourself that these are coated for sublimation.
Littleshark
Re: 3oz Mugs
Hello BMS,
Thanks for your answer.
Do you have a mug press able to sublimate mug with 53mm diameter ?
Re: 3oz Mugs
Littleshark;88880 wrote:Hello BMS,
No we don't have anything that will do that size from stock. Options would be to use a domestic oven, JML halogen oven or a mini 3d press.
Littleshark
Re: 3oz Mugs
Ok BMS, thanks.
