ciss problem
Re: ciss problem
I have just bought a new empty ciss kit. but can't get printer to print sometimes its got lines through and sometimes doesn't print at all.
i filled it with sublimation ink then ran install new cartridge process. I then ran a few cleaning processors and now there is plenty ink in cartridges and tubes. i have removed the small rubber plugs (not large one used to fill ink) and replaced them with the clear plastic ones with tube sticking up.
I can't seem to get printer to work and have ran more cleaning processors to see if that helps but it's done nothing can anyone help me out here i'm going to smash the stupid thing haha
Matthew
Re: ciss problem
Is there air in the lines? Have you tried purging the ink through to the cart's yet? Put a syringe (no needle) into the cart hole and draw back until the air is removed and ink runs freely.
I find it useful to print blocks of CMYK rather than just run nozzle checks as this can help to identify and clear problems.
Re: ciss problem
where do i put the syringe? sorry never had this problem before
Matthew
Re: ciss problem
Into the holes in the bottom of the carts (remove from printer) The syringe should fit snugly into the hole to ensure a seal, sometimes you have to tilt it ever so slightly.
Re: ciss problem
Thanks justin i'll try it tomorrow when i go back to office and let you know what happens. i've been in the print business for years doing flyers, business cards, posters etc and logo design. just got into sublimation as new venture but had nothing but problems finding right supplier, equipment etc haha
Matthew
Re: ciss problem
Are you able to pull pure liquid ink through this CIS to confirm that the ink is flowing correctly? If so then, assuming there are no air locks, the CIS should be fine. Sometimes it's all too easy to introduce an air lock in these systems when you're priming them from new and this will cause printing problems.
I think, from a previous post, that you've bought a non standard Epson printer and a non standard CIS to use with sublimation ink. Whilst I do understand the reasons of cost to do this, there is no guarantees that this printer will work perfectly with sublimation inks (I sincerely hope it does for your sake), but when Epson/ Ricoh printers are tested by Sawgrass often the entry level printers fail because the printheads used are not suitable for running sublimation inks constantly.
We'll all keep our fingers (and toes) crossed that the CIS issue can be resolved and the printer will fire up properly for you.
Re: ciss problem
Hi Martin
i did notice when i was running process when i first installed it that there was a lot of gaps in hose so maybe it has just sucked air through i'll try what justin suggested tomorrow.
I have since bought a new printer and ciss after wasting time and money with other printer haha
Matthew
Re: ciss problem
Hi Justin
Tried putting syringes in bottom of cartridges but it just creates a vacum and the syringes just want to pull back it can see in the tubes that there is air as has bits of ink then gap then ink etc. i tried printing again and it came out with lines through and some colours missing.
Anymore suggestions to what i can do i would be very grateful?
Matthew
Re: ciss problem
Just spoke to company i got ciss from they told me to pull air out from top of cartridges did that and cartridges are now full of ink
Printed a test image came through better but still with lines so i ran a clean process and now it won't come out at all apart from black with lines through.
Matthew
