Hi Chaps and Chappettes
I'm having problems with both my Epson printers. SX235w and SX435. Both have great colours for cheap printers, but here is the problem: I'm currently having to feed one sheet to them each time I want to print.
They both printed off a stack of paper with no issues when I first set them up, and pretty shortly after they decided they wouldn't take the paper if it was in a stack or just sat as a single sheet, it has to be at a certain angle to take it.
I'm pretty sure there must be a setting or a level that isn't set up right, but can someone just tell me if I'm being ridiculous?
Feed Issues with TWO Epson Printers
- DS Designs
Re: Feed Issues with TWO Epson Printers
Not sure if this will help, but I had a similar issue with it not feeding from a stack of paper on a 220... I used platten clean in an aerosol tin and cleaned the feed roller and it works fine now...not sure yours is the same issue though
Users browsing this forum: Google [Bot] and 4 guests
