Sheet FRP and Gloss hardboard
Help in finding new products.
Andrew
Re: Sheet FRP and Gloss hardboard
Post by Andrew »
Hi All.
Anyone ever use sheet stock? Trying to get some pricing sorted as an ongoing line. Unisub or atleast their European supplier keep promising to ring but never do. I know there are non-unisub finished items out there which would do the job so anyone seen these on their travels..... at a decent cost!
Happy to hear from Martin/Graeme as well.
Cheers,
Andrew
Hi Andrew,
What sizes are you looking for and is this gloss one side, gloss both sides, matte one side of matte both sides?
There is also FRP and Hardboard...
Options are:
Hardboard:
SHEETHB1 Gloss 1 side* 3,17 mm x 1200 x 2400 mm
SHEETHB2 Gloss 1 side 3,17 mm x 1200 x 1200 mm
SHEETHB3 Gloss 1 side 3,17 mm x 1200 x 600 mm
SHEETHB4 Matte 1 side* 3,17 mm x 1200 x 2400 mm
SHEETHB5 Matte 1 side 3,17 mm x 1200 x 1200 mm
SHEETHB6 Matte 1 side 3,17 mm x 1200 x 600 mm
SHEETHB7 Matte 2 sides* 3,17 mm x 1200 x 2400 mm
SHEETHB8 Matte 2 sides 3,17 mm x 1200 x 1200 mm
SHEETHB9 Matte 2 sides 3,17 mm x 1200 x 600 mm
SHEETHB10 Gloss 1 side* 6,35 mm x 1200 x 2400 mm
SHEETHB11 Gloss 1 side 6,35 mm x 1200 x 1200 mm
SHEETHB12 Gloss 1 side 6,35 mm x 1200 x 600 mm
FRP:
SHEETFRP1 Gloss 1 side* 2,3 mm x 1200 x 2400 mm
SHEETFRP2 Gloss 1 side 2,3 mm x 1200 x 1200 mm
SHEETFRP3 Gloss 1 side 2,3 mm x 1200 x 600 mm
SHEETFRP4 Matte 1 side* 2,3 mm x 1200 x 2400 mm
SHEETFRP5 Matte 1 side 2,3 mm x 1200 x 1200 mm
SHEETFRP6 Matte 1 side 2,3 mm x 1200 x 600 mm
SHEETFRP7 Gloss 2 sides* 2,3 mm x 1200 x 2400 mm
SHEETFRP8 Gloss 2 sides 2,3 mm x 1200 x 1200 mm
SHEETFRP9 Gloss 2 sides 2,3 mm x 1200 x 600 mm
SHEETFRP10 Matte 2 sides* 2,3 mm x 1200 x 2400 mm
SHEETFRP11 Matte 2 sides 2,3 mm x 1200 x 1200 mm
SHEETFRP12 Matte 2 sides 2,3 mm x 1200 x 600 mm
*lead times on 1200 x 2400 may apply
Andrew
Post by Andrew »
I think we are just looking at the gloss for both versions currently. Size comes down to cost and whatever is cheapest as we will cut it down to 600 x 400 sizes to work with anyway. Double sided and single side for frp and single for hardboard.
Never actually used matte as the gloss always gives such a good print.
