heat press just broke !
guarddog14
Re: heat press just broke !
Post by guarddog14 »
the bracket that runs through the middle of my press has just completed snapped off , im guessing its going to be easier to buy a new one than repair anyone got a old one they want to sell :tongue: lol
NikGrey
Post by NikGrey »
What is it?
If it's an Adkins like mine that 'Bracket' will be Mild Steel so you can get that repaired (Welded) quite cheap ! if it were me I would have had it repaired in a few minutes.
If it's cast, then just make a couple of plates and bolt it back together.
same if its aluminum.
get in the workshop man and get it sorted, it's simple.
OR, pay the postage from and to and I will fix it at a reasonable rate.
Depends on which press it is though - as I first asked, what is it?
Depending on the press, depends if it's worth getting fixed
NikGrey
Post by NikGrey »
I have enough work on in my workshop as it is but to help members get this type of thing fixed I can repair Mild Steel breaks for £20 (and you pay postage from and to me).
Just to give you an idea of prices - it will not be expensive to fix these problems, not whilst I am able to do it anyway.
neilb
Post by neilb »
guarddog14;86186 wrote:the bracket that runs through the middle of my press has just completed snapped off , im guessing its going to be easier to buy a new one than repair anyone got a old one they want to sell :tongue: lol
Did you get hold of one? I've a small flatbed you can borrow for a short while if you're stuck.
Frostee
Post by Frostee »
My mates business partner did this with theirs. When he first got it he had it set so tight you had to literally hang off it to close it. Needless to say he snapped it within a month. They just used some long bolts and bolted it back together. It did keep snapping after every 50 presses or so but guessing there's something stronger you could use than a standard bolt. If not at least it means you can still use it whilst looking for a new one
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
