Thought this may be of interest to some on here.
DTG Printer
Not mine came across it on gumtree. Anyone on here use one of these?
DTG for just over £1000
Re: DTG for just over £1000
THESE MACHINES NEED USING EVERY DAY
The heads get blocked very easy and need fulltime attention ,have looked on ebay for one,so did a lot of research on these machines
Directdesignsupplied.co.uk
FutureProject
I wouldn't buy a second hand epson for printing invoices.. they are cracking printers with regular use and maintenence but get them clogged and youve got a hell of a headache at minimum, or a useless machine.
Sorry if this is classes as reviving an old thread as its a week old but just to add by 2 cents into it. I did quite a bit of research on these things when we first started out. We were looking at a new one for £1800 from spain but quickly decided against it. They're known as DIYDTG printers.
they will need printing on every day to avoid clogging but like any dtg really but with the DIY ones theres no real support as its all very much just hacked together. plus the quality these things produce in comparison to a purpose built machine is pretty bad. Theres a reason the dedicated machines cost 10-20x as much and even those require a bit of TLC to keep them running nicely!
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
