Where can I get?
A11kns
Re: Where can I get?
Post by A11kns »
Been given an order to produce some mugs but not sure where I can get the style.
This is is the mug
any idea where I can get them from?
cheers
dan
JMugs
Has thanked: 9 times
Post by JMugs »
The transfer press.
I think JMUGS thinks this is a latte mug which I am not sure about. A Latte is the closest you will get as you will not be able to source this exact style for subbing.
JMugs
Post by JMugs »
I was looking on my phone but was aware it was not a latte mug, however I hadn't noticed the fluting at the top.
The Transfer Press do a tall slim straight mug which is what I was referring to.....alas not sure about the fluting though.
Cheers all
Janners
A11kns
Post by A11kns »
Cheers guys... I have been searching but I'm at a loss so far.
Doubt you'll find this for sublimation work, as the sides aren't straight - appear to curve all the way, with more so at the top.
A11kns
Post by A11kns »
I was thinking this too... I guess I will have to find a mug (straight) thats a close match.
What kind of quantities are you wanting? you could get them made for you if you're needing enough.
A11kns
Post by A11kns »
do you have the mugs then pisquee? I'm needing 30
No I don't have them, I was meaning if you were needing a decent quantity (1000+) you could get them mugs made to your own spec.
