Silicone Sheets
Re: Silicone Sheets
Post by GoonerGary »
I was about to throw out an old mug press which has a crease in the blanket, but otherwise still works great.
I thought I could use it for pressing smaller mugs if I added a silicone sheet around the mug.
Where could I get silicone sheets, what thickness and how much extra pressing time would be required roughly?
Re: Silicone Sheets
GoonerGary;85327 wrote:I was about to throw out an old mug press which has a crease in the blanket,
Can you not replace the blanket?
Re: Silicone Sheets
No it's too old. Novachrome said it wouldn't be worth it.
edit, found my answer 1.5mm silicone should do it. If anyone knows how much extra time is required to compensate that would save me a few mug wastages (charity shop donations)!
