Page 1 of 2
Re: Cycling Water Bottles
Posted: 11 Feb 2014, 14:25
by rachelwhisk
I have been looking around for some water bottles for a local cycling club to print onto. This area is totally new to me. Can anyone recommend anything for me?
Rach
Posted: 11 Feb 2014, 14:26
by rachelwhisk
They would preferably have to be plastic not sure if that helps
Posted: 12 Feb 2014, 11:30
by rachelwhisk
Anyone god any ideas on this. Google is being very unhelpful to me :(
Posted: 12 Feb 2014, 11:42
by socialgiraffe
you will not be able to use the sublimation process to print on to plastic bottles for cycling. Dye Sublimation requires a temperature of about 180 degrees for 60 seconds plus (depending on the item you are printing), plastic will melt at this temperature. The only thing I would suggest is metal water bottles but they are considerably more expensive, or if the numbers are worth it then outsource to a screen printer.
Note that the screen printer will need the capabilities of cylindrical printing and ideally know about plastic as both areas are problematic with screen print.
Good luck :-)
Posted: 12 Feb 2014, 11:52
by John G
Hi Rach,
You could try SPSeu - they've just had a management buy-out but are still trading as normal, I think. - Water Bottles
You need to be a member but it shouldn't be a problem getting an account.
Cheers John
Posted: 12 Feb 2014, 11:56
by rachelwhisk
Thanks very much John and socialgiraffe This has really been bugging me! Thank you very much
Posted: 05 Jul 2014, 23:31
by NikGrey
I have just been asked for Water Bottles, Aluminium ones seem like the only way to go at the moment (they want 750ml) .. but at £4.32 exc delivery (BMS) It's starting to look like an expensive item to retail :(
Only just started looking though - I need 20 for the first order.
Arghh. there is a problem with the Listawood Trade site :(
Posted: 14 Jul 2014, 13:26
by theTbird
Posted: 14 Jul 2014, 14:22
by Neilb78
hiya TBird I brought some of them from xpres aand have a adkins mug press, I take it I will need to purchase another blanket for them to fit
Posted: 14 Jul 2014, 15:15
by theTbird
Do you have an element for Bone China mugs?
Ours isn't an Adkins, but that's the element we use for aluminium bottles :)
Em
