Cycling Water Bottles
rachelwhisk
Re: Cycling Water Bottles
Post by rachelwhisk »
I have been looking around for some water bottles for a local cycling club to print onto. This area is totally new to me. Can anyone recommend anything for me?
Rach
rachelwhisk
They would preferably have to be plastic not sure if that helps
rachelwhisk
Anyone god any ideas on this. Google is being very unhelpful to me :(
you will not be able to use the sublimation process to print on to plastic bottles for cycling. Dye Sublimation requires a temperature of about 180 degrees for 60 seconds plus (depending on the item you are printing), plastic will melt at this temperature. The only thing I would suggest is metal water bottles but they are considerably more expensive, or if the numbers are worth it then outsource to a screen printer.
Note that the screen printer will need the capabilities of cylindrical printing and ideally know about plastic as both areas are problematic with screen print.
Good luck :-)
John G
Post by John G »
Hi Rach,
You could try SPSeu - they've just had a management buy-out but are still trading as normal, I think. - Water Bottles
You need to be a member but it shouldn't be a problem getting an account.
Cheers John
rachelwhisk
Thanks very much John and socialgiraffe This has really been bugging me! Thank you very much
NikGrey
Post by NikGrey »
I have just been asked for Water Bottles, Aluminium ones seem like the only way to go at the moment (they want 750ml) .. but at £4.32 exc delivery (BMS) It's starting to look like an expensive item to retail :(
Only just started looking though - I need 20 for the first order.
Arghh. there is a problem with the Listawood Trade site :(
Neilb78
Post by Neilb78 »
hiya TBird I brought some of them from xpres aand have a adkins mug press, I take it I will need to purchase another blanket for them to fit
theTbird
Post by theTbird »
Do you have an element for Bone China mugs?
Ours isn't an Adkins, but that's the element we use for aluminium bottles :)
Em
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
