Hi all..will give Martin a ring in the morning but just incase someone can help now..have just installed a new B1100 printer with easyflow setup.
First problem is cannot get yellow to print and not showing on the nozzle check either, have done 3-4 head cleans and let it rest but nothing and its also the only tube thats not full of dye and also blue is coming out brown but thinks a profile issue or maybe just because theres no yellow.. which leads me to profiles..have followed the Artainium setup disc and clicked to install profile but when i go to printer profile in the print setup in Elements 7 it shows nothing about Artainium or icc profile..really need help with this as need it printing ASAP
Glen
Easyflow and profile help..
- Has thanked: 11 times
- Been thanked: 9 times
Re: Easyflow and profile help..
Have you tried purging the yellow through? Using the syringe with no needle attached, make sure it's snugly in the hole under the cart and draw back the air until ink flows freely.
Will try that now mate...any ideas on the profile setup..?Justin wrote:Have you tried purging the yellow through? Using the syringe with no needle attached, make sure it's snugly in the hole under the cart and draw back the air until ink flows freely.
Not sure on Elements, I tend to use coreldraw for everything.
Is profile deffo installed ok? Can you see it in any other progs?
