Blank clocks
Re: Blank clocks
Hi
Does anyone know where I can buy blank round clocks that arent sublimation? Not CD sized, around 9''.
Not sure where else to put this.
Re: Blank clocks
Too much work involved. Thats what I originally did when I started 8 years ago. The clocks I am looking for are plastic where the face is left blank for you to print on. Listawood have something simliar at £13 per unit, where I am from theres someone doing these wholesale at £2.75 so there must be out there somewhere. Clocks are 50% of my business but not this style.
Re: Blank clocks
Does it need to be plastic or would a white faced hardboard be suitable?Mugman71;81495 wrote:Too much work involved. Thats what I originally did when I started 8 years ago. The clocks I am looking for are plastic where the face is left blank for you to print on. Listawood have something simliar at £13 per unit, where I am from theres someone doing these wholesale at £2.75 so there must be out there somewhere. Clocks are 50% of my business but not this style.
Re: Blank clocks
If you want a decent volume at a time then you can get ???mm diameter white faced circles cut in hardboard with a hole in the centre for a clock movement.Mugman71;81497 wrote:White faced hardboard would be fine.
Re: Blank clocks
If it is just a circle with a hole in the middle then we can help, but I think you want this plus a black plastic surround like the UniSub product. If that's the case then you'll need to source the black plastic bit separately or buy the UniSub kit.Mugman71;81497 wrote:White faced hardboard would be fine.
