Page 1 of 2
Re: Reddy browns going green?
Posted: 18 Dec 2013, 20:38
by JMugs
If I print Pauls mug Colour check template on to Aluminium sheet it looks beautiful. Print an image with a light reddy brown flecked wall and mum/husband child with brownish hair and the whole image takes on a greenish hue! Far less noticable in the blue/greys/ whites of tops.
I have done a nozzle check and it is perfect.
Don't know if it makes a difference but the image was processed in photoshop, saved as a Jpeg, but I print in Coreldraw. Image looks fine on screen.
So before I try a new profile does anybody have any ideas?
Janners
Posted: 18 Dec 2013, 21:31
by JMugs
Hmm printed the image out on my trusty little Ricoh and it's fine.
Oh well...the mystery continues.
Janners.
Posted: 18 Dec 2013, 22:47
by NikGrey
I did it also with my trusty Ricoh, made a Mug and it's great :)
Posted: 19 Dec 2013, 12:28
by pisquee
Can you not print straight from Photoshop to eliminate any colour management mismatches from loading it into Corel? Photoshop is very good with colour management and printing.
Posted: 19 Dec 2013, 12:40
by JMugs
Hi P.
I may have to start using photoshop, BUT the odd thing is it prints fine when printed from the A4 Ricoh. If I put both prints together though, I would say the Ricoh has a very slight pink tinge, whilst the epson has a more distinct green tinge. Just to add to the confusion, if yuo didn't know the brickwork was supposed to have a red fleck in it, you would say the epson print with green hue was better.
The epson I wll go back to basics and do a profile on it.
I'll PM you...avoid coffee whilst reading, you make make a mess!
Janners
Posted: 05 Jan 2014, 20:00
by JMugs
[ATTACH=CONFIG]2330[/ATTACH]
Well cracked it in the end.
I will go through this in stages as it's the way my mind works.
Problem Suddenly images have strong green colour cast.
What Changed - Printer was moved and turned on end.
What else - When fired up after move spat ink out, this was when colour cast happened.
What was my response - Look for something that's changed, found lines full of air bubbles.
Remedy - pull out all cartridges, re-insert, initiat fill, nozzle check (perfect), re-profile, print.....still green.
Response - repeat process ensuring every stage is exactly as it should be, same outcome, green colour cast .
Now what?- Read, ponder, question, read, ponder etc.
Learn - Green colour cast caused by no profile application. So read, watch videos, question, all was exactly as it should be.
Now what? - Read, ponder, question...etc.
Learn - Green colour cast caused by lack of magenta, nozzle check...perfect. Although that doesn't use much ink..
Thinking - When printing magenta draw is much greater than on a nozzle check. ink drawn by vacuum pump, vaccum pump must work as print is good just wrong colour.
Mad cap idea
- Air vents on cartridges blocked?
Solution - Pull off little air vents (7, total value less than 1p!), now run ink test printing a thick long line from each cartridge...all good, nozzle check (as expected - all good), re-profile, print image WOOP WOOP, normal quality returned!
So 2 weeks of head scratching, muttering, goodness knows how much searching of the internet, and the problem was a poxy blocked air vent! Yes that thing sat on a memory card...
[ATTACH=CONFIG]2332[/ATTACH]
Anyway sorted.
Janners
Posted: 05 Jan 2014, 20:09
by pisquee
Glad you've got there in the end!
Well done for working through things.
Posted: 05 Jan 2014, 20:14
by JMugs
Hi Pisq.
It has been quite a ride. The input from yourself and Paul has been most welcome.
Janners
Posted: 05 May 2018, 18:44
by aNDI
I followed this with interest as I also have an Epson that prints with a green hue. Sometimes it is all over the image sometimes it is only in patches. I will follow your instruction and see if it works for me. One question, did you leave the air vents off altogether or did you replace them after unblocking them.
Posted: 05 May 2018, 18:52
by JMugs
Left them off.
Janners
