is it too much to expect that all mugs in a case be useable?!
spongerobinson
Re: is it too much to expect that all mugs in a case be useable?!
Post by spongerobinson »
hi all,
having an issue this morning with a case of smug mugs. nearly every one I take from the case has dirt around the rims. I'm talking black lines/marks under the coating. Our last case had similar issues, but in smaller numbers. Am I being too fussy? I personally wouldn't buy a mug that had black marks/dirt on the rim!
RogerC
Post by RogerC »
Perfectly acceptable to require eachl and every mug to be 'fit for purpose'. I only use BMS mugs and have never had a problem with them. If I was in your position I would be asking for replacement mugs of 'merchantable' quality or a refund and go elsewhere.
spongerobinson
RogerC;80526 wrote:Perfectly acceptable to require eachl and every mug to be 'fit for purpose'. I only use BMS mugs and have never had a problem with them. If I was in your position I would be asking for replacement mugs of 'merchantable' quality or a refund and go elsewhere.
Thats exactly what I've done Roger. A new case is going to be shipped to me tomorrow, and be hand checked by the supplier before sending.
I normally get the European mugs from BMS, but these are Smug Mugs which BMS don't supply. We used to get the espresso mugs from BMS, but they haven't had stock in a long time, so had to find an alternative.
We also got a case similar to the European from BMS as they were out of stock last week, and there were 7 breakages in the case. Never had a single breakage from BMS yet (touch wood!!) in the year we've been doing this, so I'll certainly be going back to BMS now that they have stock again!
Renniwano
Post by Renniwano »
I had this with another supplier a while back and they were replaced.. and that's how it should be..
You wouldn't go to a supermarket and buy a loaf of bread to find half the slices were unusable.. so why should this be any different.
spongerobinson
They don't seem to have a problem replacing them which is good to see, I just hope they haven't had a whole batch that is bad, as I have an order to get out!! :confused:
spongerobinson
These are the sort of issues I've been finding, just so people can be aware to look out for it themselves. Am I being too fussy?
It seems like the supplier may have gotten a dodgy batch, so they are going to take it up with their manufacturers, and I will receive a new case tomorrow, which has been hand checked, so happy enough with how it's been handled for now!
[ATTACH=CONFIG]2246[/ATTACH]
vB_ID:2246
vB_ID:2246
2013-12-09 12.10.16.jpg (64.57 KiB) Viewed 388 times
NikGrey
Post by NikGrey »
There's no way I would use those - would YOU buy one like that? I wouldn't.
Your not being too fussy at all in my opinion.
spongerobinson
NikGrey;80536 wrote:There's no way I would use those - would YOU buy one like that? I wouldn't.
I certainly wouldn't Nik! Anyway, hopefully it gets sorted, and I can't exactly blame the supplier as it's clearly a problem coming from the factory. Just wanted to make people aware.
I think the more that small companies like us let our suppliers know about problems, the better for us all!
spongerobinson;80527 wrote:Thats exactly what I've done Roger. A new case is going to be shipped to me tomorrow, and be hand checked by the supplier before sending.
Good to hear! Yes the espresso have been a long while coming back, but they are on their way for 2014 :)
spongerobinson
bms;80571 wrote:Good to hear! Yes the espresso have been a long while coming back, but they are on their way for 2014 :)
Great to hear! Would also be great to be able to get RN coated smug mugs from yourselves...they really are a nice little shape and size! :tongue:
