Do you use Protective Paper?
Stevo
Re: Do you use Protective Paper?
Post by Stevo »
Hello everyone, I've just watched a Conde video of how to press a mug, in the video Britney uses Protective Paper which is normal printer paper wrapped around the transfer paper.
So if I buy a BMS DF1 press, do I need to use protective paper with each press I do:confused:
Thanks in advance. :wink:
NikGrey
Post by NikGrey »
I started off not using it, then I watched a video and started using it - then went to see a Pro at work who doesn't use it.. so - upshot is I don't.
Angloman
Post by Angloman »
whats protective paper lol, not me either
Directdesignsupplied.co.uk
rossdv8
Post by rossdv8 »
i didn't use it in my old mug press, then found I was getting transfer through to the heat wrap that would sometimes come through. It only happened if I pressed a mug using a partial transfer after I've done some full wrap prints. i.e. the transfer paper is cut smaller so I have a white border.
Anyway, I've since started using paper, either plain copy paper, or greaseproof baking paper and after having the same thing happen on my flat press I now use paper or teflon there too.
I stopped using teflon on the mug press because it seemed to be messing with the print image. I was getting strange lines on the image. They stopped when I stopped using the teflon and went back to paper.
Protective paper stops any stray ink getting from your transfers onto the pressing plate/blanket of the press, which can ruin future prints. Doesn't have to be anything special really, just a protective layer - paper works out cheap, and is disposable which means when it gets stray ink printed on it, you can churck it away and get another sheet.
Renniwano
Post by Renniwano »
I use a strip of silicone baking paper.. just saves any potential blow out on the blanket :)
gorgall2
Post by gorgall2 »
Used to use it all the time, until BMS said it wasn't necessary. Not had any problems.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Use it in my flat presses, never in mug presses. No logic there really.
Janners.
Stevo
Post by Stevo »
Thanks for all replays, and yes this is the wrong section to put it in LOL I think I'll just try it out without the paper and see what happens, after all its not mentioned in the BMS DF 1 PDF manual I've read.
Moved thread into Mug Press section :-)
I never use a protective sheet.
