Printware and Promotion 'Live' 2014. Who's going?
Discuss recent vists & upcoming shows.
NikGrey
Re: Printware and Promotion 'Live' 2014. Who's going?
Post by NikGrey »
NEC - 23rd - 25th Feb 2014.
Still waiting to be able to register - I have found a place to stay not too far away. Will be taking the car but parking will probably cost a bomb so will see about other ways of getting there from the posh hotel.
Who else here is going to this event?
You cant register on the main page here:
But you can HERE.
Parking is normally about £6.00 and Listawood normally host a meeting for dye sub members on the Sunday I think.
NikGrey
Post by NikGrey »
Was just working out the best way to do it, will probably travel down on the Sunday and do Monday and Tuesday at the show, if it is £6 that will be cheaper than a taxi for sure..
I drive there and back in one day and you are only an hour further on!
Andrew
Post by Andrew »
I struggle to do 2 hours at that show let alone 2 days. If it's a first time then a full day should be plenty......especially if you don't screeprint or embroider. Well worth a look if you're new to it all though.
mrs maggot
Post by mrs maggot »
remember the hotels are likely to put a premium on, as its not the only event on at the NEC at that time, its normally tucked away in their small print, if you really need to stay then i would say stay a bit further away from the NEC - but as others have said one day should be all you will need unless there are some new exhibitors
James990
Post by James990 »
Doubt if I will be going, the last time I tried to go, I bent the car!!
tlworkwear
Post by tlworkwear »
I'll be going, would be good to see some of the other members there hopefully. Will keep an eye out for the Listawood meeting as this will be my 4th time going to P&P but the first since offering sublimation so will almost be like a new experience for me!
smo
Post by smo »
I will be driving up and back in the day. I find 4 hours is usually enough for just about any show and Printware & Promotion is pretty small compared to most at the NEC.
[CENTER]
I am in! well.. 99%
