Double sided round metal keyrings
- Has thanked: 11 times
- Been thanked: 9 times
Re: Double sided round metal keyrings
Yes, you can get inserts that fit both sides, I've had them from Transfer Press but not for a long time.
I will have a look. Want to produce a keyring with club logo on one side and a number on the other.
I do them for a customer from The Transfer Press.. but I will be honest if you are looking for a lot of them make sure you ask if they are in stock, if not you could wait a while for them..
Worth to give nicci a call from sublimetals. They can cut whatever you want.
I have made an order with the Transfer Press.. only ordered 10 to see how I get on as I'm getting my flat press this week. Thanks again guys!
Got my keyrings from the transfer press.. Got a little question.. How do you stick the discs in the keyring? I was expecting some double sided tape, but there isn't any. Do I hot glue them in?
I used a very small amount of super glue in the centre, any more than that and it will spread over the front image..... Messy.
Double sided tape would be ideal but possibly harder to position if you don't get it spur on first time, at least with glue you have a few seconds
When I do them I use contact adhesive..
