The NEW CASE-iD 3C
3D Sublimation
Jelliskin
Re: The NEW CASE-iD 3C
Post by Jelliskin »
Hi Guys,
Check out our latest 3D sublimation machine. It can produce 3 cases of 1 large tablet case in 4 minutes,
Ben Swift
CASE-iD
Jelliskin
Post by Jelliskin »
For further information go to www.case-id.net
[TABLE="class: tablepress tablepress-id-1 dataTable, width: 0]
[TR="class: row-1 odd]
[TH="class: column-1 sorting_disabled, bgcolor: #C71C77, align: left]PRODUCT[/TH]
[TH="class: column-2 sorting_disabled, bgcolor: #C71C77, align: left](£) POUND STERLING[/TH]
[TH="class: column-3 sorting_disabled, bgcolor: #C71C77, align: left]($) US DOLLARS[/TH]
[TH="class: column-4 sorting_disabled, bgcolor: #C71C77, align: left](€) EUROS[/TH]
[/TR]
[TR="class: row-2 even]
[TD="class: column-1, bgcolor: #FFFFFF, align: left]CASE-iD MiniPress V2.0 NEW
The A5 MiniPress is capable of printing a case in 3 minutes. Internal Vacuum pump system, ideal for a streamlined retail operation. Several developments have been made to this machine, now has perfect ink transfer. Improved image distortion. Large full colour touch screen.[/TD]
[TD="class: column-2, bgcolor: #FFFFFF, align: left][COLOR=00000]3495.00[/COLOR][/TD]
[TD="class: column-3, bgcolor: #FFFFFF, align: left][COLOR=00000]5300.00[/COLOR][/TD]
[TD="class: column-4, bgcolor: #FFFFFF, align: left][COLOR=00000]4000.00[/COLOR][/TD]
[/TR]
[TR="class: row-3 odd]
[TD="class: column-1, bgcolor: #FFFFFF, align: left]CASE-iD 3C NEW
The B4 3C is capable of printing 3 cases in 4 minutes. A unique Double Pump Internal Vacuum System. This machine has been designed and built specifically for the job. It has a triple channel suction system to allow a perfect wrap of 3 individual cases. It also includes a 7" high resolution touch screen.[/TD]
[TD="class: column-2, bgcolor: #FFFFFF, align: left][COLOR=00000]5249.00[/COLOR][/TD]
[TD="class: column-3, bgcolor: #FFFFFF, align: left][COLOR=00000]8250.00[/COLOR][/TD]
[TD="class: column-4, bgcolor: #FFFFFF, align: left][COLOR=00000]6200.00[/COLOR][/TD]
[/TR]
[/TABLE]
Prices exclude VAT where applicable.
Tite003
Post by Tite003 »
HI,
I´ve seen other machines working with a golden film, instead of silver. What is the difference between them?
Also, another machines I´ve seen have problems to get the same results in the front of the conver than in the sides, being the sides results poorer. Does this happen with this machine too?
I note in the video that you did not show the cases being placed on a cooling jig after pressing. Was this just an omission to the process or do your cases not require this part of the process?
I know that you sell the best cases but was just wondering if they still need to be cooled on a jig before placing on the phone or packaged for retail.
