Ricoh 3110 DN No Yellow
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Ricoh 3110 DN No Yellow
Post by JMugs »
Last night I needed to replace the Black and Cyan cartridges, and I could see that the Yellow and Magenta cartridges were almost out as well, sure enough this morning they needed replacing.
Print one photographic mug and all is fine, print 10 mugs with blue text and all is fine, back to do some more photographic mugs ... image is off colour. Nozzle check shows no yellow at all! Did a head clean (just incase) no change.
I shall speak to Sawgrass in the morning, also left a message for the guys at BMS to contact me. So we shall see what that brings.
Question is anybody else encountered this?
Janners.
JMugs;76044 wrote:Last night I needed to replace the Black and Cyan cartridges, and I could see that the Yellow and Magenta cartridges were almost out as well, sure enough this morning they needed replacing.
Janners.
Sent a reply to your email. Please reply via email as I won't be on here much.
JMugs
Post by JMugs »
Thanks Martin
JMugs
Post by JMugs »
SORTED.
Must be Martin's magic vibes at BMS.
Gave up, turned it off. Got curious so turned it back on. It clicked and whirred for quite a few minutes, then declared itself ready.
Printed a nozzle check .... perfect.
Janners
technick
Post by technick »
Eeeeesh - just had a hairy moment there during a 600 coaster run with a missing blue - glad i found this post!
