Stick-On Labels with web address for T-shirts
MugNewbie
Re: Stick-On Labels with web address for T-shirts
Post by MugNewbie »
I've been looking for stick-on labels that I can get printed with our web address, that we can stick over the care label on our FOTL t-shirts.
I came across these which look great, http://www.name-labels.com/name-labels-new.php , until I read the small print that they melt if ironed.... I didn't want to have to warn customer's about ironing the label just in case!
Does anyone know of a similar product that just sticks on, stays on and doesn't melt(!), or failing that a good iron-on product that we can use with the heat press?
I don't need to order huge amounts just a few hundred.
purpledragon
Post by purpledragon »
We sell labels by the metre that you can heat press or iron on
dazzul
Post by dazzul »
OOOOOOOOOOOOOOOOOOOOOOOOOOO Purple could you inbox me a photo of said heat press label. me like
MugNewbie
Post by MugNewbie »
Ooh, could I see a pic too?! Will they last a while when washed and what price are they? I just need something to cover a FOTL approx 2.5cm/ 3cm wide with web address on, white label with black text.
Thank you!
purpledragon
MugNewbie;75319 wrote:Ooh, could I see a pic too?! Will they last a while when washed and what price are they? I just need something to cover a FOTL approx 2.5cm/ 3cm wide with web address on, white label with black text.
Thank you!
hi ill fire a pic off toyou both when i get to the shop tomorrow
MugNewbie
Post by MugNewbie »
Thanks, much appreciated!
dazzul
Post by dazzul »
You forgot me? OH MAN im off to cry now.
purpledragon
havnt forgot anyone just didnt get chance yesterday apologies guys
anyway they are £2.50 per metre and are 45mm wide
ILL TRY PUTTING A PIC UP IN THIS POST WISH ME LUCK !!!
[ATTACH=CONFIG]1894[/ATTACH]
vB_ID:1894
vB_ID:1894
iron on labels.jpg (84.33 KiB) Viewed 284 times
purpledragon
Thank you!
Just to answer a couple of those questions will they last a while ? well i still have mine ironed into my work shirt and thats had quite a few washes since doing it i wont pretend they will last as long as flex for example but they should stay put for a fair old while . the width is fixed im afraid 45mm wide although i suppose you could trim them down with scissors or a guillotine i can print the text to what ever size you like within those constaints
MugNewbie
Post by MugNewbie »
Hiya
Thanks for the pic - I'll drop you a pm :-)
