Hi Guys
Up until now I have been using The Magic Touch WOW 7.2 Paper for dark garments using my OKI White printer. I ordered exactly the same on Thursday but this time a box of WOW 7.5 turned up. Looking around I do not think there is any difference.
However I have just come to use it and there are problems...
Printed the image on the i sheet and then placed this and the m sheet between the release paper and pressed for the recommended time and temp. When I came to peel the two sheets apart, the entire white backing peels covering the whole of the i-sheet.
I have noticed that with WOW 7.2 the m and i sheet paper sizes are slightly different. But in this box both papers are exactly the same size. So I am thinking that there is a problem with the transfer sheets supplied and that it might be a bad batch.
I am just putting this on the forum to see if anyone who uses this stuff has some times and temps or has noticed the difference and can point me in the right direction.
WOW 7.2 versus WOW 7.5 ... HELP!
