Ricoh SG 3110dn Waste ink tank full - what to do?
rob88
Re: Ricoh SG 3110dn Waste ink tank full - what to do?
Post by rob88 »
The waste ink tank is full already, hasn't even had a full set of 4 cartridges through it...
What do I need to do?
Is there a way of emptying it and resetting or is a replacement required? If so where's the best place to get one?
Thank you in advance!
Rob.
i would contact your supplier. no chance that one set full up waste ink tank :/
AdrianH
Post by AdrianH »
http://www.youtube.com/watch?v=xPZgjepU8zc
Not sure if that is of help or not, can you see if tank is full?
Adrian
It does seem like there is something wrong and AdrianH's post should sort you out.
If not there is a work around for Ricoh waste tanks where you can take them apart, clean them out and insert some paper under the sensor. Look on you tube Conde channel and I am pretty sure they have a video. You will need to check that you can do it for your model though.
Good luck
You should update your firmware as well.
SubliBlanks
Post by SubliBlanks »
You can do a reset although i would not recommend it. We would only ever say use this method if its urgently needed.
Hold Up & Down arrow for 5 seconds then press enter
Engine Maintinance "enter"
3008003 - Enter / Enter again
RST : Waste : RC : EXEC
Enter / OK Enter
Left Arrow
RST : Waste : R
3008004 / Enter / Enter / Enter
Then Exit
In all honesty we don't find the 3110 printers that reliable, we have been through 4 in under 1 year - we too had the maintenance tank problem, streaking and banding issues. We first thought it was a paper missfeed in relation to the banding and streaking, but most of our problems was related to air in the tubes. We believe when the inks was running low it was pulling air through causing it to run maintenance and forcing the air into the maintenance tank. I recommend the Epson 4015 printer any day.
SB SubliBlanks - 0843 886 1065
UK Dye Sublimation supplies
Email : sales@subliblanks.com
Site : www.subliblanks.com
