Cutter Software = what do you use
- mrs maggot
Re: Cutter Software = what do you use
just downloaded a trial of SignCut, but before i sign my life and money away what do other people use ??
the Signblazer i have used for many years, is very unstable and indeed has caused a lot of issues on my pc - apparently the patch that was offered to people after the untimely death of its creator had a very well hidden trojan virus in it. i have artcut here already i have not loaded it as people say its rubbish - but then in recent weeks my views on signblazer have changed
I use Signblazer but then I'm not much of a designer, my tshirts are mostly text or very simple logos or designs usually supplied by the customer. I know that my anti virus alerted me when the patch was downloaded and once the software was up and running I allowed the anti virus to delete the patch. I hope I don't jinx myself by saying I haven't noticed any issues on my pc because of it
Used CutStudio for the Roland GX-24. Very simple as we import lines drawn in Illustrator, but you can draw and do text in it if you like.
Also has a X&Y Multiple copy option too, very handy.
J.
J.
Day Out Photography
www.dayoutphotography.co.uk | facebook.com/DayOutPhotography | twitter.com/DayOutPhotos
m. 07817 118 717
m. 07817 118 717
I use artcut 2007 because it came with the cutter and I don't do a lot of cutting it's not the best but it works.
Dave271069
i use silouette as i have a cameo, its easy and great to use as many will agree, its whats out there that scares me to buy another cutter so im saving up for a bn-20 and will use the software tht comes with that
Im using SignGo Pro. Does what it says on the tin and more... although not as good as FlexiSign. (Not the cloud version!)
FlexiStarter 10. perfect for ALL jobs. contour cut, standard cut etc.... FlexiSign for more pro functions.
I would recomed flexistarter. stable and in expensive.
we use magicut from TMT - easy, similar to Corel, but not great with illustrator files
- mrs maggot
tricia, im interested that you say you deleted the patch, as without it it will revert to using it in trial mode, i presume you have only deleted the patch prgramme, not the actual patch that works away behind the scenes.
paul looks to be around the same price as sign cut, i quess both will take some getting used to.
