Help required please (again)
Dave271069
Re: Help required please (again)
Post by Dave271069 »
im definatly getting my £10 worth on this forum :-)
some one has given me a image to print using vinyl for a hen do, can anyone make it simpler for me to cut out, im thinking that the mask is a bit complicated, im using silhouette cameo software if that helps. thanks in advace
Dave
[ATTACH=CONFIG]1817[/ATTACH]
vB_ID:1817
vB_ID:1817
Micheal Mcay hen t-shirt.jpeg (60 KiB) Viewed 235 times
Dave271069
Also the edges need sorting out as they are not very clear if you can see what i mean like on the elbows
You do like to hurl yourself at lightening speed in to the deep end don't you LOL!!!!
have a look at the below which might be a better option. It was done very quickly in Photoshop so its not 100% but you get the idea.
If (as in my example) the image is going on a pink tee shirt, then filter out the background black and also all the white. You are left with just the black areas of the image which you can then use TTC to press on the garment.
Just a suggestion which can be sorted within 10 mins, it took me 2 to get to the stage below, so tidy up is not going to take that long.
[ATTACH=CONFIG]1818[/ATTACH]
If however you must have the black and the white then not sure yet how I would go about it.
vB_ID:1818
vB_ID:1818
Micheal Mcay hen t-shirt 2.jpg (83.36 KiB) Viewed 235 times
Dave271069
I'm not sure yet how the customer wants it, waiting for her to get back. But I didn't think of TTC was going down the vinyl route so will have to wait and see what she wants.
cheers for your pic though.
Johnny
Post by Johnny »
How does this suit you?
J.
vB_ID:1821
vB_ID:1821
Dave271069
Johnny;72448 wrote:How does this suit you?
J.
many many thanks, just what I wwanted cheers Dave
