Trying to set my windows vista computer up for my epson 9400 but cant remember how to set the print preferances for sub icc profile below is the result im getting (its not supposed to be black) can anyone shed some light on where im going wrong it works fine on my other computer running xp but that uses an earlier version of photo shop so not sure whats going wrong
[ATTACH=CONFIG]1796[/ATTACH]
thanks
Brett
www.mybiggerpicture.com
how to set my printer up for sublimation
- purpledragon
Re: how to set my printer up for sublimation
- vB_ID:1796
- 2905[1].jpg (4.31 KiB) Viewed 19 times
Photoshop manages colours, and select your ICC here
in printer driver, turn off colour management
in print driver select settings as they were for printing the ICC profile targets
- purpledragon
its set for photo hop manages colour so bit odd reallypisquee;71823 wrote:Photoshop manages colours, and select your ICC here
Don't think this is a Vista v XP issue. All colour management is set up within PhotoShop. Check all your settings are the same in each version of PhotoShop.purpledragon;71811 wrote:Trying to set my windows vista computer up for my epson 9400 but cant remember how to set the print preferances for sub icc profile below is the result im getting (its not supposed to be black) can anyone shed some light on where im going wrong it works fine on my other computer running xp but that uses an earlier version of photo shop so not sure whats going wrong
thanks
Brett
Assuming you have the ICC profile for your 9400 then just follow the setup instructions your supplier gave you for the version of PhotoShop you are using (lots of version help files on the Sawgrass website and the only difference will be in the actual profile you append).
sawgrass have a set by step pdf, use that, will be the same principle
