Re: Hello All
Posted: 03 May 2013, 20:34
by mfatty500
Howdy! I'm Mike and I know ABSOLUTELY NOTHING about sublimation, but hoping to learn. I do mostly heat press vinyl and the usual methods of T-Shirt printing.
Mike
Re: Hello All
Posted: 03 May 2013, 20:42
by jennywren
Welcome if you can use a heat press then learning about sublimation should not be too much of a problem for you. Glass of cheer and a bit of reading the threads and away you go
Re: Hello All
Posted: 03 May 2013, 20:47
by mfatty500
Thanks for the reply jenny, i can but am a little confused about what images to use or create, resolutions etc. I have corel and flexi for design programs what do some others use?
Re: Hello All
Posted: 03 May 2013, 21:07
by arko
Hi Mike and welcome. I wasnt into sublimation when I joined and still havent purchased the equipment although I do vinyl and transfer tees and signs etc. If I now had the money, after being a member here, I would have thought I now have enough knowledge and support (from the members) to go ahead and start. Im using signgo, corel, PS and AI fior images and illustrations. Best of luck in your new venture. :_)
Re: Hello All
Posted: 03 May 2013, 21:54
Hi Mike and welcome to the forum :-)
DSF Admin
Re: Hello All
Posted: 03 May 2013, 21:59
by mfatty500
Thanks for the warm welcomes. Looking to learn about this sublimation stuff.
Re: Hello All
Posted: 03 May 2013, 22:01
by Renniwano
Welcome to the forum :)
Re: Hello All
Posted: 04 May 2013, 08:39
by bms
Welcome along Mike, lots to learn :)
Re: Hello All
Posted: 04 May 2013, 15:25
by Ian M
Welcome to the forum Mike. :biggrin:
