Hello All
Re: Hello All
Howdy! I'm Mike and I know ABSOLUTELY NOTHING about sublimation, but hoping to learn. I do mostly heat press vinyl and the usual methods of T-Shirt printing.
Mike
Mike
Re: Hello All
Welcome if you can use a heat press then learning about sublimation should not be too much of a problem for you. Glass of cheer and a bit of reading the threads and away you go
Re: Hello All
Thanks for the reply jenny, i can but am a little confused about what images to use or create, resolutions etc. I have corel and flexi for design programs what do some others use?
Re: Hello All
Hi Mike and welcome. I wasnt into sublimation when I joined and still havent purchased the equipment although I do vinyl and transfer tees and signs etc. If I now had the money, after being a member here, I would have thought I now have enough knowledge and support (from the members) to go ahead and start. Im using signgo, corel, PS and AI fior images and illustrations. Best of luck in your new venture. :_)
