I dropped the pressure down to 40g but after pressing i realised even that was too much, there were cuts into the plastic backing, it was only when peeling i found them, so tonight i will try a lower setting.
I grabbed a cheap t shirt from peacocks to use as its opposite me and i got it for a quid or so, 100% cotton and in a dark navy blue.
I took the logo font and used that in illustrator, appllied a curve to it and then did the cut, I then took one of my skulls and changed it adding scroll work and other features. Now i havent weeded before and after weeding these i realised that lots of detail is fine, if you have an hour to spend weeding!!!!!
Here are the pictures of my first ever vinyl cut, weed and press.
freshly cut
split press
Final result
Really happy how it came out and how fine i got the cuts to go. Next i will be trying a multi layer cut with some really high gloss chrome vinyl.
