espon stylus pro 7600
ssp
Re: espon stylus pro 7600
Post by ssp »
i have the opprotunity of buying an 7600 that has been fully serviced and overhauled by a service agent. It will come with stand and catch bins. This is what has been done to the unit
Carriage re-greased, Capping stations cleaned / replaced , Tension on all motors checked and re-calibrated, Paper feed Checked, Printheads Checked and Cleaned to ensure all nozzles are perfect, Waste Tank emptied and cleaned,Firmware updated.
The unit is in excellent condition and ready to go i can have it for £445
Just need to know can if this is ok for sub ink use?
thanks
Andrew
Post by Andrew »
All should be fine for sublimation and they are decent printers. Get a readout to see how many prints it has done etc.
Yup, they work great - get some refill carts for the sub ink, and you're set once you've done an "init fill" to flush the current inks, and fill with he new inks.
We'll be selling one of ours off soon which already is set up for sublimation inks.
ssp;70782 wrote:i have the opprotunity of buying an 7600 that has been fully serviced and overhauled by a service agent. It will come with stand and catch bins. This is what has been done to the unit
thanks
Yes all good to be used with sublimation inks. 220ml cartridges are available for this printer (as well as 110ml versions). Profiles are also available free of charge from Sawgrass for their sublimation ink so all looks good (and a bargain) !
purpledragon
Post by purpledragon »
bms;70829 wrote:Yes all good to be used with sublimation inks. 220ml cartridges are available for this printer (as well as 110ml versions). Profiles are also available free of charge from Sawgrass for their sublimation ink so all looks good (and a bargain) !
wanna buy some cheap sawgrass ink lol
You can get bigger 440ml carts too (if you want) though the 200-300ml (approx) seem to be the more standard sizes. These are essentially the same printer as the 9600, which is the 44" version. carts, maintenance tank are interchangable - ICC profiles tend to cover both the 7600 and 9600 together too. So, if you're looking at ank ink manufacturer who only have 9600 profiles made, they should work fine on the 7600 too, but getting a custom one made is best.
