Does anyone know what is applied to FRP to make it suitable for sublimation?
I have a customer that requires double sided labels with a hole for hanging. The large luggage tags were used initially and, whilst the print quality is fine, they are really a bit too too small and thick. I was thinking of posting something on FreeIndex to see if any plastic manufacturers are able to produce custom cut FRP - but I know that some sort of polymer resin is applied to the FRP to make it suitable for sublimation. Double-sided aluminium would also be good but I haven't seen this available anywhere either. Failing that, does anyone know of any alternative off-the-shelf products that might fit the bill? I'm only looking for small-ish volumes (maybe 100 a year).
Thanks!
Custom cut FRP blanks?
- mrs maggot
Re: Custom cut FRP blanks?
coralgraph and others sell a fluid you apply to products to make it suitable, never used it myself, but its been discussed on here before
Thanks Laura - I can pass the details on to plastic manufacturers but don't fancy the DIY approach with this stuff. It looks far too messy and complicated!
I might have found a simpler solution; I've remembered that I have some of the compressed fiber coasters from BMS. I haven't tried printing them before but if the quality of small-ish text is good enough and they can be cut/punched cleanly then I could get two labels out of a single placemat.
Discofish Designs Ltd. | www.discofish.co.uk | info@discofish.co.uk
