Just got a swing heat press as i want to start printing on t-shirts and coasters/placemats, but i have never done it before.
Does anyone have any hints or tips? please
Many thanks,
Ive actually had this issue recently and trying to figure out a decent fix for it. I have one of those 4 in 1 presses which means that when I have the normal plate on then it is just secured by wing nuts which keep loosening during pressing haha. I might try to find a couple of washers but not sure if that will do anything.Mossy88;70058 wrote:Make sure you check the bolts now and then on the plate to be tight enough, haha mine fell in half yesterday and couldn't pick it up of course as it was 190 degrees!
Prob because it was a cheaper one
Hmm, sounds like cheap quality...that can really be a pain in the a**, having to check the bolts everytime you use it...Mossy88;70185 wrote:Mines just a normal swing press but i guess every time you put it down it loosen a bit. awkward as hell to put it back together.
