Water Bottles?
Stitch Up
Re: Water Bottles?
Post by Stitch Up »
What's the time & temp for alu water bottles?
Can these be pressed in a standard 11oz mug press?
Cheers
John
Re: Water Bottles?
We suggest:
Press at 170-180 degrees for 2 minutes with the DF160 (other presses times may vary). In our DF14 we recommend an idle time of 110, press temp of 165 and a time of 90 seconds. Use light pressure.
They may fit in a standard press with the silicon wraps to pad them out, but it depends on how far you can adjust your press. The light pressure is important as you can easily dent them with the pressure of the wrap.
