New toys arrived!!
smo
Re: New toys arrived!!
Post by smo »
We took delivery of a new toy....an Adkins Beta A2 press to sit next to our Adkins Beta A3 presses (2 off) in our pressing room - its a lovely bit of kit but weighs a ton!!
[ATTACH=CONFIG]1666[/ATTACH][ATTACH=CONFIG]1667[/ATTACH][ATTACH=CONFIG]1668[/ATTACH]
vB_ID:1668
vB_ID:1668
20130326_152433 (Small).jpg (48.27 KiB) Viewed 437 times
vB_ID:1667
vB_ID:1667
20130326_152425 (Small).jpg (42.28 KiB) Viewed 437 times
vB_ID:1666
vB_ID:1666
20130326_151231 (Small).jpg (31.66 KiB) Viewed 437 times
[CENTER]
Glad you said "WE" at the start, lifting that on your own could do serious damage :eek:
What on earth will you be pressing?
smo
Post by smo »
I did move it on my own after myself and a collegue carried it to the pressing room, which happens to be upstairs!!!
We mostly press chromaluxe panels, got plans for a really BIG press later this year but that will have a room all of its own as it weighs over 500kg and requires a new 3-phase power supply too!
[CENTER]
Maccbean
Post by Maccbean »
smo;68477 wrote:I did move it on my own after myself and a collegue carried it to the pressing room, which happens to be upstairs!!!
Can I ask how much you are paying for your new 3-phase power supply to be installed? I've heard that it's terribly expensive and not everyone can have it.
smo
Post by smo »
We're not - its that expensive!
We had western power come around (they own the network in our area) and was quoted a minimum of £22,000+VAT to install 3 phase. Its crazy as the 3 phase pole it comes from is not more than 100m away in a field next to us so its not a hard job (ie: no roads to dig etc.). We were told though that if we were on the industrial estate a few miles away it would be £3,000+vat approx - I guess this is the price we pay for being in a beautiful building in a scenic valley surrounded by fields, forest and lovely views!
When we need 3 phase we are going down the diesel generator route, although that is a whole new ball game with its own pitfalls and problems.
[CENTER]
Maccbean
Post by Maccbean »
smo;70589 wrote:We're not - its that expensive!
Gulp...HOW MUCH??? I was thinking of getting a quote for my new business, but don't think I'll bother! Thanks.
smo
Post by smo »
Maccbean;70590 wrote:Gulp...HOW MUCH??? I was thinking of getting a quote for my new business, but don't think I'll bother! Thanks.
It does vary wildly but even if the connection is right outside your premises you are looking at 3K+ to get it connected, there is nothing cheap about it and you have no option but to go to the network operator in your area.
[CENTER]
Reg
Post by Reg »
Why not use an inverter and run off your single phase it'll be much cheaper,
smo
Post by smo »
Inverters cant cope with the load from a heating element. They are generally designed for use with a 1-2hp 3 phase motor which draws much less current than we will. Generator is the only viable alternative option.
[CENTER]
