The need to keep ink flowing!
AdamB
Re: The need to keep ink flowing!
Post by AdamB »
As all will know, I have certainly had some issues with the old b1100 printer over the last year or so and have replacement printers, replacement ciss systems and new ink.
We all know and have been told the importance of keeping ink flowing but I just wanted to reiterate the importance of doing this.
My system runs the artainium ink from sawgrass and when I first started in this I knew just how expensive the ink was so I was a little dubious of running a test print as I didn't want to 'waste' ink - a major error!
By not keeping the ink flowing you will 'probably' cause some sort of blockage which 'could' result in numerous head cleans - and the ink used in these head cleans is so much more than doing an actual test print.
So, since December I make sure that I run a print through my system at least every 48hrs - this may be too much but it works for me and to date I have had NO PROBLEMS and my ink seems to be lasting longer as I have avoided numerous head-cleans!
I run this through my b1100 (a 4 colour print as the b1100 is a 4 ink system):
[ATTACH=CONFIG]1626[/ATTACH]
and I always get a clear print (print out may look faded as I'm printing with my profile onto plain paper):
[ATTACH=CONFIG]1627[/ATTACH]
So, a little investment in preparation and looking after your equipment will help in the long-run :)
vB_ID:1627
vB_ID:1627
vB_ID:1626
vB_ID:1626
AdamB
Post by AdamB »
good link - I was thinking of something like this but it's only good if your pc/laptop is left on constantly as the program sends a print at regular intervals to the printer (plus I work on a laptop so take it with me each time I leave work).
If I went away for a week I don't think I would leave my PC on as my thoughts would be more on an electrical fire (overheating) rather than a blocked printer lol :)
Has thanked: 11 times
You can set a scheduled task to print from within windows but like you say, PC needs to be on all the while.
Forgive me for sounding cynical but this seeks very expensive for something that just appears to be a different interface for the scheduled task manager? Maybe I'm missing something, I only took a fleeting glance :-)
swimwivsquid
Post by swimwivsquid »
I'm probably talking something up here but I have a Workforce 1100 which is the US equivalent of the B1100 and since abandoning Sawgrass inks I have not had blocking problems like I used to. I can leave it for a week or two do a quick nozzle check and start printing. Never used to be able to do that. I know you guys are not supposed to talk about this subject but i thought it was worth mentioning.
