Car Rally Plates
draig
Re: Car Rally Plates
Post by draig »
Does anyone do these? or can recommend a good company that does.
Looking for Rally Plates similar to old style Monte Carlo shape, needing 250-300.
Sharon
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
I think Martin at BMS can do custom cut.
Andrew
Post by Andrew »
I would think Martin can only offer straight edged. Aren't the Monte Carlo style with the curved top? If so it would probably be more awkward to get custom shaped. I have looked into various routered designs in the past which was the only realistic option I would think £4-5 + vat for a printed/shaped sign would be the cheapest you could get these done for sublimation metal from past experience.
JMugs
Post by JMugs »
Next door to Martin, I think, is a metal work specialist.
Then again I may be wrong.
Janners.
JMugs;67060 wrote:Next door to Martin, I think, is a metal work specialist.
Janners.
There is indeed!
Ian M
Post by Ian M »
Sharon, are you looking for just blanks to print yourself or printed/finished ones?
