Epson D120 Icc profiles disc wanted.
Re: Epson D120 Icc profiles disc wanted.
Hi I currently have an Epson D120 printer and im wanting to use it for the rotech sumblimation inks but i have not got the rotech disc with all the icc rotech profiles on, does anyone know where i can get hold of this disc please.
Danni
Danni
Are you using Rotech ink at the moment or just looking to get the profile in advance? The profile will be provided by the supplier of the inks so you can get it when you get the inks (or the Easyflow system). Most users on here are using the Artainium inks though. Interested to hear why you're considering Rotech...
I'm guessing here.....because there is quite a large seller on Ebay? I think Signal Inkjet supply the ICC Profile with their CISS Systems but not sure if the supply the Profile if you just purchase Sublimation Ink from them.
I will be using Artainium, thanks Martin
Phil
Phil
Life is like a jigsaw puzzle........i'm sure i'm missing some pieces!
Hi.
Thanks for the replys Martin and Phil.
Im currently using the Rotech inks on my Epson D88 but my D88 is on its way out hence the reason im needing the rotech disc with the icc rotech setting on so i can start using the D120.
I still have quite alot of the Rotech ink left so i thought i may aswell use it with the D120 until i can get some more funds and buy a new system.
We don't have the Rotech profiles as we supply Artainium inks, but your original supplier of the Rotech inks should supply you with the Rotech profile if you ask for it. Let us know if they refuse!
Hi Martin.bms wrote:We don't have the Rotech profiles as we supply Artainium inks, but your original supplier of the Rotech inks should supply you with the Rotech profile if you ask for it. Let us know if they refuse!
I sent Sawgrass an email 3 days ago and still no reply.
Once i have used what Rotech i have i will be buying the Artainium inks from yourself as i get my blanks form you now. i find keeping to the same supplier is much easier and to be honest i have never had no complaints for your blanks
So keep up the good work.
Have you tried the distributor of the inks rather than going direct to Sawgrass, i.e. whoever you bought the Rotech inks from originally?
Hi Martin.bms wrote:Have you tried the distributor of the inks rather than going direct to Sawgrass, i.e. whoever you bought the Rotech inks from originally?
I bought the inks from ebay a while back and now the person i bought them from dont that account anymore.
What a 'Top-Guy' you are Martin. You even help out the competition!bms wrote:pm sent with some contact details...
Phil
