Just had a order for 20 clip on ties,
1st question, anyone know a good source for them but not at £4-£5 each (cheaper) ?
2nd question will logos printed from a versacam be ok? That one is for you socialgiraffe ?
dave
Clip on ties
Re: Clip on ties
Hi Dave
I am pretty sure there will be a transfer material that sticks to it. Just need to know what sort of material it is. You may find that they are made of polyester in which case they can obviously be dye subbed.
Need to know what colour you need. I can find black ones and navy ones at £1.95 plus VAT
I also note that PREMIER do sell them in a range of colours so looking at Ralawise there are a bucket load of colours at £3.95 - £5.90 plus VAT each. Ralawise are a trade only company so presumably they should in actual fact sell for a lot more.
SG
SG
Dave271069
Re: Clip on ties
I have a contract with ralawise. Just found out he needs 20 red ones by next week and I need to be around the £8 mark. If its possible it might be worth me doing it at a loss leader as im sure he has lots of other orders in t
he pipeline.
he pipeline.
Re: Clip on ties
See below
http://www.ethicstar.com/basic-tie-clips.html
£4.20 pack rate (10 per pack)
http://peterdrew.com/products/clip-on-ties
£3.95 each (you may be able to do a deal)
Both of the above are 100% polyester so depending on what he requires on the tie you may be able to get away with dye sub.
Re: Clip on ties
Ralawise are £3.65 +VAT on pack rate. You may be able to negotiate carton rate which is 20p cheaper.
Not sure if PeterDrew is with VAT or not, I would assume Ethic Star are plus VAT.
Re: Clip on ties
If you use Siser C print PU textile vinyl from Grafityp it can be applied to Cotton, nylon, polycotton blends and lycra so it should cover whichever material your ties are made from. I use quite a bit of it and it prints and weeds very well. You can get it in matt or satin finish and it is a softer feeling material then a lot of other vinyls.
