corel paint shop pro for sublimation
Any OS, software in here.
rezyac
Re: corel paint shop pro for sublimation
Post by rezyac »
hi is corel paint shop pro good for sublimation as i found it cheaper than photoshop :)
Has thanked: 11 times
If you're using a Ricoh printer with Powerdriver you can print from any software you like, otherwise it needs to be able to work with the profile.Photoshop is far better, take a look at slightly older versions of Elements as these aren't expensive.
rezyac;65341 wrote:hi is corel paint shop pro good for sublimation as i found it cheaper than photoshop :)
photoshop elements 6 can cost you no more then £15 is perfect for the job.
RogerC
Post by RogerC »
If you want PS Elements try looking at the digital photographic magazines for freebies.....I got my copy of Elements 8 that way.
