Hi
Were looking for some wedding cake boxes kind of like these ones
http://www.ebay.co.uk/itm/White-Glossy- ... 19d5e354ca
but 100mmx100mmx100mm we need about 40
Would anyone be able to do these and if so how much? We just need the box cut out, we will do the ribbon
Wedding cake boxes
Re: Wedding cake boxes
Matthew
I would get the boxes from here...
http://www.rajapack.co.uk/cardboard-box ... BC110.html
although if you only need 40 then it would not take that much to buy flat sheets of card then cut and stick the boxes together yourself
And then cut them myself using something like the below.....
http://direct.hobbycraft.co.uk/products ... 296805.htm
http://www.fiskarscraft.co.uk/Products/ ... hapeCutter
I've got a template somewhere I'm sure if you tell me what kind of file you can cut with and I'll see if I can save it as it!!?! (Does that make sense!>!) So you can do them yourself if that helps?!?!?
