Page 1 of 3
Re: blacks gong brown again
Posted: 27 Jan 2013, 22:22
by bigj2552
on a pic someone sent in for an iphone case.
blacks going brown - to much heat ? or to much time ? - to much pressure ? or a crap pic ?
off to try again :rolleyes: - prob them all lol
here is the original pic from customer -which has been cropped and brightened up, cause it was really dark
http://i1264.photobucket.com/albums/jj4 ... cdc1c4.png
and heres what the thing is turning out like
http://i1264.photobucket.com/albums/jj4 ... 9db5b6.jpg
have tried lowering temps, less time, less pressure, nothing.
black come out fine on mugs
Posted: 27 Jan 2013, 22:33
If you're using a Ricoh I'd say it was too much heat and/or time. What settings are you using?
Posted: 27 Jan 2013, 22:37
by bigj2552
ha - wished i was justin - brother 5910dw :rolleyes:
temp -180 -time - 180 - presure -heavy
tried temp-175 - time - 175 - med pressure - still same
blacks come out fine on my mugs -so inks are ok
the first setting has worked fine for all other colours - bar tonight with the black
edit -
doing a colour chart test on one of my mugs - to see if it is the ink, or printer needs re-profiling again.
post pic in 5 mins
Posted: 27 Jan 2013, 23:13
by bigj2552
had a 10oz in mug press - went to loosen mug press for the 15oz mug - dam thing fell apart :rolleyes:.
now need to wait till it cools before i can sort it -
coffee and some de-stress tabs
What press you using?
Posted: 27 Jan 2013, 23:20
by bigj2552
DF1 Press justin - just needs re tightened - just need to let it cool.....been here before and forgot it was that hot - OUCH !
Posted: 27 Jan 2013, 23:38
by bigj2552
right sorted - have down 3 rows of square, 6 across
first row - RGB
second row - CMYK
third row - PATONE
just to see what the colour difference is....
why patone ? i,m sure i down something with this and it came out better than expected !
Posted: 27 Jan 2013, 23:45
by Paul
bigJ! your image is brown
not to much but i can clearly enough see that is lot of brown in it!
Posted: 27 Jan 2013, 23:54
by bigj2552
wait till you see the mug i just done....think i really need another profile -YIKES! - my ink is getting on for around the 8mth mark and if i remember right, JSR said he had to get his redone as the composition of the inks change with age
uploading to photo bucket now..hold on guys
Posted: 27 Jan 2013, 23:59
by Paul
try to press this one on other side of the mug
